Applications Systems
Process Monitoring on AS/400 produces error in SAM
Process Monitoring on AS/400 produces error in SAM. You can browse and select processes for monitoring but actual polling results in an SNMP monitor error: No process info found. This error occurs because the AS/400 only provide limited data.
You can browse and select processes for AS/400 monitoring, but actual polling results in an SNMP monitor error:
This is a known issue with this particular device. To poll processes effectively, SAM needs to know how much CPU & Memory the process is consuming. This is part of the standard HOST-RESOURCES MIB.
IBM has a watered-down SNMP agent on the AS/400 provides limited information via SNMP. SAM can see the list of processes, but when trying to poll, critical pieces of information are missing.
There are a few vendors with custom SNMP agents you can install to replace the built in SNMP agent with a more complete one. For example, you can purchase a third-party agent from Comtek. See http://www.comtekservices.com/os400.html. (© 2018 COMTEK Services, LLC., obtained from www.comtekservices.com on December 19, 2018.)
