Tools
Problem starting CatTools_Client instance error when running a backup activity in Kiwi CatTools
This article shows how to resolve an issue where Kiwi CatTools shows the error: "Problem starting CatTools_Client instance #1. Error:-2147024882: Not enough memory resources are available to complete this operation.<CR><LF>" when running a backup activity.
10/12/2020 7:20 PM
10/12/2020 7:20 PM
When running a Device.Backup.Running Config activity in Kiwi CatTools, it throws an error similar below.
Kiwi CatTools
Reinstall Kiwi CatTools:
  • Create a backup copy of the whole CatTools install folder (C:\Program Files (x86)\CatTools3)
  • Uninstall Kiwi CatTools and reboot the machine
  • Reinstall Kiwi CatTools
  • After the install, stop the CatTools service through services.msc
  • Copy the folders and files below from the backup CatTools folder and paste them into the current CatTools installation folder to overwrite them.
    • Captured Data folder
    • Configs folder
    • Dated Configs folder
    • Reports folder
    • TFTP folder
    • Variations folder
    • KiwiCatTools-Settings.ini file
    • KiwiDB-CatTools.kdb file
    • KiwiDB-CatTools.ldb file
  • Start the Kiwi CatTools service through services.msc
  • Run the backup activity again
