Applications Systems
PowerCLI commands are not running through using PowerShell component in SAM due to error on Importing VMware module
This article describes how to resolve issue on importing a VMware module using PowerShell script component.
When testing a PowerShell component with a PowerCLI command, the test is successful; however, when importing the VMware module, the error "module file was not found in any module directory" occurs.
SolarWinds runs scripts within a restricted Job Object Container. This could be responsible for the "Access Denied" errors. Switching to Remote Host triggers a WinRM session, which creates a standard, unrestricted security context for the Service Account.
Using WinRM (Remote Host) ensures a proper logon session. This should resolve the issue where the process defaults to NT authority\system and will allow the script to run under the correct Service Account identity
Due to the execution mode of the component set to Local Host, where process defaults to NT authority\system. In Local Host mode, SolarWinds runs scripts within a restricted Job Object Container. This could be responsible for the "Access Denied" errors.
Prerequisites:
Please ensure WinRM is enabled and the Service Account is added to the Remote Management Users group. Run these commands on the target server in an elevated PowerShell window:
- winrm quickconfig
- Add-LocalGroupMember -Group "Remote Management Users" -Member "DOMAIN\YourServiceAccount"
- Execution Mode: Change from Local Host to Remote Host (leave defaults for other options that will appear: Port/Protocol: 5985/HTTP)
- Credentials: Assign the designated Service Account (instead of System)
- Platform to run polling job on: Ensure it is set to the correct bitness of the device (x64 or x86)
- Preferred Polling Method: Agent
