Applications Systems
Windows PowerShell monitor status is down due to "Access Denied" error message
With the PowerShell component monitor, the credential used for execution of the script is dependent upon the "Execution Mode" and the value in the "Run the script under specified account".
11/15/2018 1:59 AM
2/11/2025 7:20 PM
When monitoring with the use of Windows PowerShell scripts in SAM, you may notice its status as down due to an Access Denied error message.
Additionally, you may find following error in the application monitor's debug logging:
ERROR SolarWinds.APM.Probes.PowerShellProbe - System.Management.Automation.Remoting.PSRemotingTransportException: Connecting to remote server failed with the following error message : Access is denied. For more information, see the about_Remote_Troubleshooting Help topic.
Server Application Monitor
If the component type is Windows PowerShell Monitor, the credential used is based on the setting of the Execution Mode and the "Run the script under specified account".
  • If "Execution Mode" is Remote Host, the credential used will be the one listed under "Credential for Monitoring".
  • If "Execution Mode" is Local Host and "Run the script under specified account" is false, the credential used will be SYSTEM.
  • If "Execution Mode" is Local Host and "Run the script under specified account" is true, the credential used will be the one listed under "Credential for Monitoring".
