Tools
Ports and Domains/Firewall and AV requirements in Dameware Remote Everywhere (DRE)
Learn how to set up firewall/proxy requirements, what ports need to be allowed for outbound access, what domains need to be accessed, and which components to allow through the AV software
- How to setup Firewall/Proxy requirements for the DRE Tech Console, Agent or Applet
- What ports need to be allowed for outbound access for DRE
- What domains need to be accessed
- Which components to allow through the AV software
- This applies to both the technician and the end-user
- Ports:
- HTTP (TCP 80)
- HTTPS (TCP 443)
- No SSL inspection on TCP 443 for traffic regarding the necessary domains.
- We validate the HTTPS certificates when communicating with our web servers. So, if the firewall/proxy is intercepting this traffic through a transparent proxy and encrypting it again with the firewall/proxy's certificate, it will fail, and it needs to ensure there is no blocking of DRE domains.
- UDP 1234 - Bidirectional - Required for P2P connections
- UDP 1235 - Bidirectional - Required for P2P connections
- TCP 3377 - Outbound - Fail-over port when 443 is not accessible
- Domains:
- *.beanywhere.com
- *.mspa.n-able.com
- *.pubnub.com
- *.swi-tc.com - mandatory for using the Vaults feature and accessing the Admin Area
- *.swi-rc.com
- *.swi-dre.com
- swi-rc.cdn-sw.net
- Additional notes for Firewalls/Proxies
- The Agents should be able to reach the internet.
- No HTTPS snooping should be done on SSL (TCP 443).
- We validate the HTTPS certificates when communicating with our web servers. So, if the firewall/proxy is intercepting this traffic through a transparent proxy and encrypting it again with the firewall/proxy's certificate, it is going to fail, and it needs to make sure that there is no blocking to the domain *.mspa.n-able.com.
- Any protocol fingerprinting (some firewalls will interpret non-HTTPS traffic on 443 as malicious), should be no blocking for our domains *.mspa.n-able.com, *.beanywhere.com, *.pubnub.com, *.swi-tc.com, *.swi-rc.com, *.swi-dre.com, and swi-rc.cdn-sw.net
- The following DRE components below should be allowed by AV (only necessary if being actively blocked by AV)
- Applet: BASupApp.exe and BASupSrvc.exe
- Agent: BASupSrvcCnfg.exe and BASupTSHelper.exe
- If you can't connect to any machine from the host (technician side), the DRE component below should be allowed
- BASEClient.exe
