Tools
Portecle will not start on the Red Hat Linux GUI for Web Help Desk
This article addresses an issue on the Red Hat server with GUI where Portecle does not start using the Portecle command from within the bin folder.
Portecle command from within the bin folder.Product section
Environment
- WHD 12.2
- RedHat server
- Gnome GUI
- Open a terminal at
/usr/local/webhelpdesk/bin. - Manually start the application by executing:
java -jar ./Portecle.jar
Disclaimer: Please note, any content posted herein is provided as a suggestion or recommendation to you for your internal use. This is not part of the SolarWinds software or documentation that you purchased from SolarWinds, and the information set forth herein may come from third parties. Your organization should internally review and assess to what extent, if any, such custom scripts or recommendations will be incorporated into your environment. You elect to use third party content at your own risk, and you will be solely responsible for the incorporation of the same, if any.
