Port requirements for container monitoring in the Orion Platform
This article provides port requirements related to monitoring containers in Orion Platform products that support that feature, such as SAM and VMAN. Supported container platforms include Docker, Docker Swarm, Kubernetes (K8s), Azure Kubernetes Services (AKS), and Apache Mesos.
This article provides port requirements for monitoring containers in Orion Platform products that support that feature, including SAM and VMAN. To learn more about this feature, see Monitor containers in the Orion Platform.
Additional learning resources include:
To support container monitoring, allow all outbound communication from orchestrator machines on the following ports:
- 17778 (to the SolarWinds Information Service (SWIS) API)
- 17799 (to the Orion Cortex API)
All other ports are used for internal communication by specific orchestrators, and should not be blocked by internal orchestrator firewall rules. You can change ports in configuration files manually, but SolarWinds does not recommend doing so.
Following are port requirements for each supported container environment:
Docker
- 4043 - Container port (internal Docker communication)
- 6784 - Report/wave status (internal Docker communication)
- 17778 - SWIS
- 17799 - Cortex (Orion Platform communication)
Docker Swarm 17.12+
- 17778 - SWIS
Kubernetes
- 4043 - Target Port / Container Port (internal Docker communication)
- 17778 - SWIS
- 30043 - Node Port (internal Docker communication)
Apache Mesos
- 4043 - Mesos master server port (internal Mesos communication)
- 8080 - Deployment service (internal Mesos communication)
- 17778 - SWIS
