Ping stops working on the Orion Polling Engine
This article describes how to resolve an issue that caused Ping to stop or hang when the Orion Services are running. When this issue occurs, the assigned node statuses are stale at the last polled status.
Attention:
If you are using SolarWinds Platform 2023.2, it is likely related to a known issue affecting the JobEngine service (refer to SolarWinds Platform 2023.2 Release Notes ). It is advisable to update the SolarWinds Platform to the most recent version.
