Tools
Perform a Bulk Action to Web Help Desk Tickets
This article describes how to apply a bulk action to one or more Web Help Desk tickets.
10/24/2018 5:23 PM
5/20/2020 11:42 AM
You can create and apply a bulk action set to a set of tickets. Bulk action can also be saved as a template and shared with other users.
Web Help Desk
The following procedures describe how to create, apply, and edit a bulk action in Web Help Desk.
Create a new bulk action
  1. Log in to Web Help Help Desk.
  2. In the toolbar, click Tickets.
  3. Select the Ticket you want to modify.
    If you want to select the items across ALL pages, press and hold the Shift key before clicking on the top most check box.
  4. Locate the Bulk Action feature at the bottom of the screen.
  5. In the Bulk Action field, click the + icon.
  6. In the Bulk Action Details screen, select the items you want to change.
  7. In the Save Bulk Action as field, enter a name for the action.
  8. (Optional) Select the Shared checkbox to share the bulk action with other users.
    Only a tech with admin privileges would have an option to share a bulk action.
  9. Click Save.
    The saved bulk action is stored in the Bulk Action drop-down menu.
Apply or edit a saved Bulk Action
  1. Log in to Web Help Desk.
  2. In the toolbar, click Tickets and select the tickets you want to address using Bulk Action.
  3. Click the Bulk Action drop-down menu and select an option.
  4. Click the arrow (>) icon.
    A message displays, summarizing the changes that will be applied to your selected tickets.
  5. Click OK.
    The bulk action is applied to the selected tickets.
