Security Compliance
Patch Manager Server running out of Disk Space
This article describes how to clean up your C:\ drive to prevent low disk space issues.
10/17/2018 10:23 PM
6/25/2025 7:02 PM
This article describes how to clean up the Eminentware Packages folder to prevent disk space utilization issues:
C:\Users\<DatagridServiceUser>\AppData\Local\EminentWare\Packages\
C:\Program Files\SolarWinds\Patch Manager\Server\packages\publisher\
Patch Manager
  1. Go to the Software Publishing and select the dropdown
  2. Select and step through each vendor option and filter by the file download status icon.
  3. Sort by Creation Date to identify older updates or perform this from the All Packages node.
  4. Use the Delete Content action to remove the downloaded binaries associated with those updates.
Perform the following as an alternative resolution:
  1. Right Click Software Publishing and select Synchronize Settings
  2. Select the Subscription Tab and uncheck the unwanted products  Then delete those packages from the Software Publishing Vendor lists. note: for the unneeded packages that use PackageBoot, you can recover about 1MB per package.
  3. Use the Delete action to remove the downloaded packages.
If you delete a package in a catalog, vendor, or product that is configured for synchronization, it WILL be re-synchronized at the next Patch Manager synchronization event. This behavior is different from the WSUS server, which will never re-sync a deleted package
