Parse OIDs with multiple statistic values
In some cases, an OID from a device supplies two statistical values at once. That will necessitate using the UNDP transform to parse them into separate statistics or resources in Orion.
10/31/2018 10:37 PM
1/5/2022 6:38 AM
Network Performance Monitor
n/a
Use these values in two transforms:
  • For the first value (transform):
parse((?<result>^\D*(\d+(?:\.\d+)?)), {poller_name})
For the second value (transform):
    parse(.+\s+(?<result>\D*(\d+(?:\.\d+)?)), {poller_name})
