Tools
PASV FTP command
The PASV command tells the server to enter a passive FTP session rather than Active. This allows users behind routers/firewalls to connect over FTP when they might not be able to connect over an Active (PORT) FTP session. PASV mode has the server tell the client where to connect the data port on the server.
PASV) FTP command.Product section
Common responses
- 227 FTP response code
- 421 FTP response code
- 500 FTP response code , 501 FTP response code , 502 FTP response code , 530 FTP response code
See also
- PORT FTP command
- What is Extended Passive Mode
- Detailed explanation of Active vs. Passive FTP (© 2018 Jay Ribak, available at http://slacksite.com/, obtained on December 3, 2018).
Disclaimer: Please note, any content posted here is provided as a suggestion or recommendation to you for your internal use. This is not part of the SolarWinds software or documentation that you purchased from SolarWinds, and the information set forth herein may come from third parties. Your organization should internally review and assess to what extent, if any, such custom scripts or recommendations will be incorporated into your environment. You elect to use third party content at your own risk, and you will be solely responsible for the incorporation of the same, if any.
