Overall Running vs. StartUp Config Conflicts Chart shows Unknown in NCM
When going to the NCM Summary page, you will see that the Overall Running vs. StartUp Config Conflicts Chart shows a large percentage as "Unknown".
10/15/2018 12:34 AM
10/8/2021 3:00 PM
When you view the Overall Running vs. StartUp Config Conflicts Chart in any of the NCM pages, it shows a huge percentage for "Unknown":
Network Configuration Manager
#1 There is no Startup or Running config that has been downloaded from each of the devices.
#2 There is no baseline config set for the devices to be compared to.
You must download at least one Start & Running config from the devices & set one configuration as baseline only then the correct results within this pie chart will be compared against the baseline.
Step # 1
  1. On the Web Console, go to Configs > Jobs.
  2. Select Nightly Config Backup and click Edit.
  3. On the Nightly Config Backup edit page, click Next to go to the Add Job Specific Details tab.
  4. Verify that the following are selected:
    • Running
    • Startup
  5. Click Next and then click Finish.
  6. Go back to Configs > Jobs.
  7. Select Nightly Config Backup and click Start Job.
Step #2
A. (NCM 7.8 and below) Set baseline configuration for your network through NCM Job:
  1. On the Web Console, go to Configs > Jobs. > Create New Job > "Baseline" > Next >  Select "Baseline Entire Network" > Complete the Job
B. (NCM 7.9 and above) Set baseline configuration for your network through Configuration Management:
  1. On the Web Console, Click My Dashboards > Network Configuration > Configuration Management.
  2. On the Config Management tab, expand a node to display the list of associated configs.
  3. Identify the config to use, and click Promote to Baseline.
For more information, please check the articles below:
Establish baselines as a comparison point for network config changes
Establish baselines to define approved configurations and identify changes
Once done leave the system UP and running for the next few hours, then the chart should now display the correct percentages.
