Orphaned Topology Connections Persist Despite Disabled Topology Pollers – SolarWinds Platform​
This article provides information about an issue in the SolarWinds Platform where orphaned topology connections remain visible in Maps, Network Atlas and NPM Network Topology even after topology pollers (Layer 2 and Layer 3) are disabled. It outlines the cause and provides a workaround to resolve the issue.​
4/14/2025 2:16 AM
10/20/2025 4:40 PM
In certain scenarios, users may observe that topology connections continue to appear in SolarWinds Platform Maps, Network Atlas and NPM Network Topology widget despite having disabled the associated topology pollers (e.g., L2, L3, CDP, LLDP) for specific nodes.​
This behavior results in outdated or unintended connections being displayed, which can lead to confusion and misrepresentation of the current network topology.​
Attempts to remove these connections manually or through standard database maintenance procedures may prove ineffective, as the connections reappear after a short period.​
Network Performance Monitor
The issue arises because disabling topology pollers for nodes does not automatically remove the previously collected topology data from the database. Consequently, the Topology Calculator continues to process this stale data, leading to the reappearance of outdated connections in Maps, Network Atlas and NPM Network Topology widget.
This behavior is the result of a known bug in the product, where orphaned topology data is not automatically removed when topology pollers are disabled. A product improvement is planned in a future release to address this issue by automatically cleaning orphaned topology data during standard database maintenance. However, there is no specific release date available at this time.
Workaround: Use SQL Script for Topology Data Cleanup
To remove orphaned topology data for nodes that no longer have active topology pollers, run the SQL script below. This script identifies nodes with disabled topology pollers and deletes the associated stale topology records from the database.
⚠️ Important Note: Back up the SolarWinds Platform database before executing any direct database scripts.
  1. Connect to the SolarWinds Platform server.
  2. Open Database Manager from the SolarWinds Platform folder of the start menu.
  3. Select Add Orion Server and expand the SQL server in bold.
  4. Right-click the SolarWinds Platform database and select New query.
  5. Paste the below query and select Execute Query.
    This script cleans the topology data for nodes that have the corresponding topology pollers disabled.
-- L2 CDP data
DELETE dlt FROM NodeCiscoCdpEntries dlt
LEFT JOIN Pollers p ON
    p.NetObjectID = dlt.NodeID
	AND p.NetObjectType = 'N'
	AND p.PollerType LIKE 'N.Topology_CDP.%'
WHERE p.NetObjectID IS NULL or p.Enabled = 0
-- L2 LLDP data
DELETE dlt FROM NodeLldpEntries dlt
	AND p.PollerType LIKE 'N.Topology_LLDP.%'
-- L2 Bridge/CAM data
DELETE dlt FROM NodeL2Connections dlt
	AND p.PollerType LIKE 'N.Topology_Layer2.%'
-- L3 ARP data
DELETE dlt FROM NodeL3Entries dlt
	AND p.PollerType LIKE 'N.Topology_Layer3.%'
-- L3 Routing data
DELETE dlt FROM NodeL3RoutingData dlt
	AND p.PollerType LIKE 'N.Topology_Layer3_IpRouting.%'
-- VLANs data
DELETE dlt FROM NodeVlans dlt
	AND p.PollerType LIKE 'N.Topology_Vlans.%'
-- VLANs' Ports map
DELETE dlt FROM NodePortInterfaceMap dlt
	AND p.PollerType LIKE 'N.Topology_PortsMap.%'
-- STP data
DELETE dlt FROM PortItems dlt
INNER JOIN STPRecords s ON dlt.STPRecordID = s.ID
    p.NetObjectID = s.NodeID
	AND p.PollerType LIKE 'N.Topology_STP.%'
DELETE dlt FROM STPRecords dlt
