Orion to SQL server connection time out
What to do if the Orion to the SQL server connection is timing out.
10/15/2018 4:51 PM
9/15/2022 5:31 PM
Connection to the SQL server is timing out. The timeout settings can be modified through a configuration file on the application server. It should not be needed to increase these values. Although, they do exist and can be adjusted for troubleshooting purposes.
Orion Platform
  • Stop all Orion services.
  • Create a backup of SWNetPerfMon.db, in case you need to roll it back later. The default location is: C:\Program Files (x86)\SolarWinds\Orion\SWNetPerfMon.DB.
  • Edit the SWNetPerfMon.db file in Notepad or any text editor.
  • Scroll down to the bottom of the file and change the timeout settings as follows:
Connection timeout in seconds Timeout=60
Database Command timeout in seconds CommandTimeout=600
SqlCommand.CommandTimeout in seconds SqlCommandTimeout=0
  • SqlCommandTimeout=0 is equivalent to infinite. If you have a High Availability server, you will need to edit the same value on this server.
  • Restart all Orion Services.
