Orion losing connectivity with SQL server generating events provider: Named Pipes Provider, error - Could not open a connection to SQL Server
There are a few different possible root causes when you have intermittent events within the SolarWinds application server.
5/6/2019 7:58 PM
4/26/2023 10:26 PM
This article will explain the possible root cause when you have intermittent events within SolarWinds application server.
Events and application losing connectivity with SQL database.
This can be seen frequently under Event Viewer (Solarwinds)
A network-related or instance-specific error occurred while establishing a connection to SQL Server. The server was not found or was not accessible. Verify that the instance name is correct and that SQL Server is configured to allow remote connections. (provider: Named Pipes Provider, error: 40 - Could not open a connection to SQL Server)
 A network-related or instance-specific error occurred while establishing a connection to SQL Server. The server was not found or was not accessible. Verify that the instance name is correct and that SQL Server is configured to allow remote connections. (provider: SQL Network Interfaces, error: 26 - Error Locating Server/Instance Specified)
SqlException: A connection was successfully established with the server, but then an error occurred during the pre-login handshake. (provider: TCP Provider, error: 0 - The specified network name is no longer available.)
Orion Platform
Application Server performance
SQL Server performance / Very Large Orion DB Maintained
Layer 2/3 Latency Issues
This KB post is great place to start: What to check when the Orion website and server are very slow or there is a CPU and memory spike
  • Make sure you have all the areas correctly configured and have the required hardware to run the Solarwinds application.
  • You might have an issues within the SQL Server performance where you maintained very large Orion DB Maintained
Quick Orion database health check guide This KB post will help you to understand and improve performance within the SQL server and maintaining the Orion DB.
  • Layer 2/3 Latency Issues
If you would like to monitor the connection and performance of your SQL Server, please consider one of our additional products DPA or SQL Sentry.
