Orion Web Console Polling Method menu is disabled for individual hosts in the Virtualization Polling settings
This article describes why the Polling Settings drop-down is greyed out when you try to manage individual hosts under VMware vCenter and Microsoft Hyper-V instances.
6/14/2019 4:35 PM
6/14/2019 4:35 PM
When you manage your VMware vCenter and Microsoft Hyper-V instances in the Virtualization Polling settings, the Polling Method drop-down menu is disabled for the monitored hosts.
Orion Platform
The individual hosts are monitored by their corresponding vCenter and Hyper-V software applications. Polling is controlled at the top-level instance.
Select the checkbox for the top-level vCenter or Hyper-V instance.
