Orion Web Console AD accounts are not refreshing when changing group membership
This article describes the issue when the Orion Web Console AD accounts are not refreshing when changing group membership. In addition, sporadic issues with false logins wherein an account shows a logout link in the upper right hand corner despite not being logged in.
10/16/2018 6:09 PM
2/21/2022 2:29 AM
Network Performance Monitor
This issue occurs when the Orion Web Console  is not  using forms authentication which can cause the false login and issues with the AD groups to not replicate.
Edit the web.config found in c:\inetpub\solarwinds\ to the following:
<authentication mode="Windows">
    <forms loginUrl="~/Orion/Login.aspx"/>
</authentication>
and change it to (default):
<authentication mode="Forms">
</authentication>
  After applying this, Orion should recognize the removal and addition of accounts into different AD groups.
Note: If the website is rebuilt, this change may need to be re-instated.
