Orion Traps Viewer receives SNMPv2 authentication failure traps
This article addresses an SNMPv2 authentication failure trap received by the Orion Traps Viewer.
The Orion Traps Viewer receives the following traps:SNMPv2 Authentication Failure
When this issue occurs, the device is configured for SNMPv3 and is added to Orion using Polling Method SNMPv3.
Log in to the Orion Web Console using an administrator account.
- In the URL field, change the URL to:
http://<IP address>/Orion/Admin/AdvancedConfiguration/Global.aspxwhere
<IP_address>is the IP address of your primary Orion server. -
In the Advanced Configuration Global of Orion, scroll down and locate TrapService TrapSettings.
Uncheck the
EnableGettingValueFromOIDcheckbox, and click Save. -
Log in to your primary Orion server using a local administrator account.
Launch the Orion Service Manager. See Start and stop Orion services.
Restart the SolarWinds Trap Service.
