Orion Platform 2017.3 feature: Manage Entities
Orion Platform 2017.3 adds a new, more intuitive Manage Entities page with updated styling to manage your nodes. Robust filtering, contextual commands, muted nodes at a glance, resume alerting with a click.
Key features of the Manage Entities page include:
- Robust filtering, which replaces the Group by functionality - Search for a display name or IP address and using the filters on the left to show only the nodes you are currently interested in viewing.
- Contextual commands - The command menu dynamically shows only the actions you can perform on the selected entities.
- Find muted nodes at a glance and resume alerting with a click - Rows include an icon that indicate if alerts are muted for a particular node. Click the icon to resume alerting.
- View related entities - Click the arrow at the end of a row to view interfaces related to the select nodes in the Related Entities pane.
How do I access the Manage Entities page?
- Click Settings > Manage Nodes.
- Click The New Manage Entities Page.
To switch back to the legacy page, click Commands > Switch Back to Legacy Page.
Learn more...
- Download your installation files from the SolarWinds Customer Portal.
- Open the Administrator Guide: NPM
- Read the release notes: NPM
