Orion Maps fails to load and generates an error
This article addresses an issue that prevents Orion Maps from displaying in the Orion Web Console, generating an error. Error: "An item with the same key has already been added" OrionWeb.log shows this error [Import faca86e6-8a6f-4666-8b53-df78070e13f7.OrionMap] (7646) ERROR MapRunner - (null) CreateMapTask {ID=faca86e6-8a6f-4666-8b53-df78070e13f7.OrionMap,State=Faulted,Exception=ArgumentException:"An item with the same key has already been added."}
10/25/2018 2:46 PM
3/22/2023 10:18 PM
When you open the Orion Web Console, Orion Maps fails to load and displays the following error:
When you open the OrionWeb.log (C:\ProgramData\SolarWinds\Logs\Orion) file, the following errors are recorded in the file:
ERROR MapService -
(null)  Unexpected error. SolarWinds.MapStudio.Web.MapRunnerFaultedException: An error occurred while generating map bde5d915-88bd-4ef8-a770-fa08806af7b4.OrionMap ---> System.ArgumentException: An item with the same key has already been added.
   at System.ThrowHelper.ThrowArgumentException(ExceptionResource resource)
   at System.Collections.Generic.Dictionary`2.Insert(TKey key, TValue value, Boolean add)
   at SolarWinds.MapEngine.FileSynchronization.GetFileList(MapStudioFileType fileType)
   at SolarWinds.MapEngine.FileSynchronization.SynchronizeFiles(MapStudioFileType fileType, Boolean doUpdate, Action`1 progressReportCallback)
   at SolarWinds.MapEngine.MapSynchronization.SynchronizeImportedAndUserGraphics(Boolean doUpdate, Action`1 progressReportCallback)
   at SolarWinds.MapEngine.MapSynchronization.GetSingleMapAndSubmap(SolarWindsIdentification swId, Boolean synchronizeUserGraphics)
   at SolarWinds.MapEngine.Engine.GetSingleMapAndAddTopEntities(SolarWindsIdentification swId, Boolean synchronizeUserGraphics)
   at SolarWinds.MapEngine.OrionEngine.GetMapWithoutLimitation(SolarWindsIdentification swId, Boolean disableViewLimitation, Boolean synchronizeUserGraphics)
   at MapImport.GetMapNetObject(CreateMapParameters parameters, StopwatchHelper sw, IEngine engine)
   at MapImport.SaveMap(CreateMapParameters parameters)
   at SolarWinds.MapStudio.Web.MapRunner.ImportThreadProc(Object obj)
--- End of inner exception stack trace ---
   at SolarWinds.MapStudio.Web.MapRunner.CreateMapTask.ThrowStateException()
   at SolarWinds.MapStudio.Web.MapRunner.Execute(CreateMapParameters parameters)
   at MapService.CreateMap(CreateMapParameters parameters)
   at MapService.GetMap(String sessionId)
Orion Platform
Duplicated icon graphics in the MapStudioFiles table.
  1. Run the following query against your Orion database to see if your database has this issue:
    select [FileName] from dbo.MapStudioFiles where FileType=128 and IsDeleted =
    0 group by [FileName] having count(FileId) > 1
  2. If the query does not generate results, you are finished. No intervention is required.
    If the query generates results, go to step 3.
  3. Back up the Orion SQL database.
    SolarWinds Backup can help you streamline this task.
  4. Run the following query to remove the duplicate files:
    DECLARE @file nvarchar(max)
    DECLARE cleanup_duplicated_pictures CURSOR FOR
    select [FileName] from dbo.MapStudioFiles where FileType=128 and IsDeleted = 0 group
    OPEN cleanup_duplicated_pictures
    FETCH NEXT FROM cleanup_duplicated_pictures INTO @file
    WHILE @@FETCH_STATUS = 0
    BEGIN
    delete from dbo.MapStudioFiles
    where FileId in
    ( select FileId from dbo.MapStudioFiles where [FileName] = @file and IsDeleted = 0 )
    and FileId not in
    ( select top 1 FileId from dbo.MapStudioFiles where [FileName] = @file and IsDeleted = 0 )
    END
    CLOSE cleanup_duplicated_pictures
    DEALLOCATE cleanup_duplicated_pictures
