Orion DB on SQL AlwaysOn Cluster does not reconnect after failover
The Orion database does not reconnect after a SQL cluster fails over to a secondary node in the group.
- User can try to bypass Orion limitation by setting up DNS alias which points to the currently active SQL instance. This way DNS alias will be passed to Configuration Wizard rather than physical instance or Availability Group listener.
- For product modules running on Orion Platform 2017.1 and earlier, the use of SQL AlwaysOn Availability Groups is not supported. Customers are recommended to upgrade their product modules to Orion Platform 2017.3 or later if they plan to take advantage of SQL AlwaysOn Availability Groups.
