Orion Agent Settings: Application not found
Unable to open the Orion Agent Settings after installing the agent, it will show no icon and get an error 'Application not found' when opened.
4/2/2020 8:41 PM
2/10/2025 1:15 AM
To change the agent communication mode on the remote node we go to control panel items and open Orion Agent Settings to select server-initiated or agent-initiated communication.
Network Performance Monitor
There could be a policy or security that blocking the SolarWinds.Agent.Setup to run.
- From agent server, go to C:\Program Files (x86)\SolarWinds\Agent.
- Run the file
SolarWinds.Agent.Setup as administrator and this should open the Orion Agent Settings
- Go back to control panel items, check that you were able to open the Orion Agent Settings without errors and the icon should show up now.
