Applications Systems
Oracle QA Monitor fails in SAM because Oracle Client software is not properly installed
This is an Oracle client dependency issue on the SolarWinds polling side. The component is failing in OracleQAProbe because SolarWinds cannot initialize the Oracle provider, and the UI shows: “The Oracle Client software must be properly installed” with System.Data.OracleClient requires Oracle client software version 8.1.7 or greater.
This article addresses a Server & Application Monitor (SAM) issue where Oracle User Experience Monitor components fail and show an Oracle client dependency error. The issue affects Oracle monitoring components that rely on the Oracle User Experience Monitor on the SolarWinds Platform server or the Additional Polling Engine (APE).
A common error shown in the SolarWinds web console is:
Oracle returned an error. The Oracle Client software must be properly installed to use the Oracle QA Monitor.
The underlying exception may also show:
The Oracle User Experience Monitor requires Oracle client components on the SolarWinds polling system. SolarWinds documentation states that Oracle monitoring support requires either Oracle Data Provider for .NET (ODP.NET) or Oracle Instant Client to be installed on the SolarWinds Platform server and any APEs used for polling.
If the required Oracle client components are missing, incomplete, or not configured for the polling engine, Oracle QA Monitor components can fail with Oracle client initialization errors.
Use the following steps to install the Oracle client components and configure the Oracle monitor correctly.
Step 1: Download the Oracle .NET / client installer
Download the Oracle client installer from Oracle's .NET downloads page. Oracle describes this page as the download source for ODP.NET, Oracle Client for Microsoft Tools, and ODAC packages for Oracle database connectivity.
Oracle download page
https://www.oracle.com/database/technologies/net-downloads.html
Step 2: Install the Oracle client package into the SolarWinds installation drive
Run the downloaded EXE installer and install it into the SolarWinds Platform installation drive used in the environment.
Example path used in this fix: D:\Program Files\SolarWinds\Orion
If the SolarWinds Platform is installed on another drive, use that installation path instead. SolarWinds documentation refers to this location as <Installation Directory>\SolarWinds\Orion.
Step 3: Download the 64-bit Oracle Instant Client Basic package
Download the 64-bit Oracle Instant Client Basic package from Oracle's Windows 64-bit Instant Client downloads page. Oracle lists the Basic package as the required package for OCI-based applications, and states that all installations require either the Basic or Basic Light package.
Oracle Instant Client download page : https://www.oracle.com/database/technologies/instant-client/winx64-64-downloads.html
In this case, the package used was:
instantclient-basic-windows.x64-23.26.0.0.0.zip
Oracle may publish a newer equivalent build on the same page, so use the current 64-bit Basic package if the filename has changed.
Step 4: Extract and copy the required Instant Client folders
After downloading the Instant Client ZIP file, extract the required contents and copy them into the SolarWinds Orion installation directory.
Folders used in this fix:
instantclient_23_0 -
META-INF
Copy these folders to:
SolarWinds documentation states that extracted Instant Client files should be copied into the SolarWinds Orion directory.
Step 5: Set the Oracle Driver type in the Application Monitor or template
Open the affected Application Monitor or Application Monitor Template and set the Oracle Driver type to:
Microsoft .NET Data Provider
This setting is specifically documented by SolarWinds for Oracle User Experience Monitor components after installing the Oracle client.
Step 6: Set the polling platform to 64-bit
If a 64-bit Oracle Instant Client was installed, edit the Application Monitor or Application Monitor Template and set the following under Advanced:
Platform to run polling job on = 64-bit
Step 7: Repeat on any APEs that poll the application
If the application is polled by one or more Additional Polling Engines, repeat the Oracle client installation steps on each relevant APE. SolarWinds documentation explicitly states that Oracle drivers must be installed on the SolarWinds Platform server and any APEs in the environment.
Step 8: Retest the component
After the Oracle client files are installed and the driver type is updated, retest the affected Oracle component from the SolarWinds web console.
For more information, refer to the document below:
Configure SAM to monitor Oracle database servers
