Optional Pause Mechanism for Hung WMI Nodes
An optional pause mechanism for WMI-polled nodes is implemented in SolarWinds Platform 2025.4.
A new Advanced (Centralized) Setting has been introduced with the following parameters:
- WMIErrorPauseDurationMinutes: Duration of the pause in minutes. Default is
0, which means the pause feature is disabled. - WMIErrorPauseTriggerCodes: Comma-separated list of WMI error codes that trigger the pause. Default is
0x80010002.
When a configured error code is detected during WMI polling for 3 consecutive poll cycles on a device, the system will pause further polling attempts only for that affected device for the duration specified by WMIErrorPauseDurationMinutes.
All pause events are logged with the following details for troubleshooting and visibility:
- Device identifier
- Error code that triggered the pause
- Pause duration
The pause mechanism is disabled by default and must be explicitly enabled by configuring the centralized settings. See Access the Advanced Configuration settings in the SolarWinds Platform Web Console.
To proactively monitor devices that enter a hung WMI state, you can create a custom SAM (Server & Application Monitor) component monitor that detects these paused/hung nodes and triggers alerts. This enables timely intervention, such as restarting the affected WMI service or device. Below is an example of a configured component monitor:
- Create the custom SAM component monitor using the below PowerShell script.
$category = "SolarWinds: Windows Hung Connection Benchmarks" $counter = "HungConnectionDetected" # Retrieve all instances (IP addresses) in the category $instances = [System.Diagnostics.PerformanceCounterCategory]::new($category).GetInstanceNames() $hungIps = @() foreach ($ip in $instances) { try { $value = (Get-Counter "\$category($ip)\$counter").CounterSamples.CookedValue if ($value -eq 1) { $hungIps += $ip } } catch { Write-Verbose "Failed to read counter for $ip" } } if ($hungIps.Count -gt 0) { Write-Output " Statistic.HangedConnections: 1" Write-Output " Message.HangedConnections: $($hungIps -join ', ')" } else { Write-Output " Statistic.HangedConnections: 0" }
- Assign the component monitor to the target node(s) where you want to detect hung WMI connections.
- Navigate to Alerts & Activity > Alerts > Manage Alerts > New Alert and configure an alert based on the component monitor’s output to notify administrators when a hung connection is detected.
- Obtain the Component ID from the PowerShell component details page URL to use in alert configuration.
