How to run installer for SolarWinds Platform Offline installer using the ISO file
This article shows how to run installer for SolarWinds Platform Offline installer using the ISO file.
As of SolarWinds Platform 2020.2, the offline installer is no longer available as an exe file. It is available as an ISO file.
To install the software using the ISO file, mount the ISO image on Windows as a drive, then run the executable from the Mounted Drive. Please check the following 3rd party links for the steps:
How to mount an ISO file as a drive in Windows 2012 R2, 8, 81, and 10:
https://www.youtube.com/watch?v=AFZhzYobEUQ
Mounting an ISO Image in Windows 8, 8.1 or 10:
https://www.howtogeek.com/howto/windows-vista/mount-an-iso-image-in-windows-vista/
