Object IDs and information Orion Platform polls
Listing of Object IDs and information Orion Platform polls
Note: All data is gathered on the rediscovery interval. The IP address information is gathered from all nodes.
| Poller Type Name | OID Name | OID Value |
| Description | ||
| N.Topology.Snmp.Layer2 | dot1dTpFdbTable | 1.3.6.1.2.1.17.4.3 |
| A table that contains information about unicast entries for which the bridge has forwarding and/or filtering information. This information is used by the transparent bridging function in determining how to propagate a received frame. | ||
| N.Topology.Snmp.Layer2 | dot1dBasePortTable | 1.3.6.1.2.1.17.1.4 |
| A table that contains generic information about every port that is associated with this bridge. Transparent, source-route, and srt ports are included. | ||
| N.Topology.Snmp.Layer2 | dot1qVlanCurrentTable | 1.3.6.1.2.1.17.7.1.4.2 |
| A table containing current configuration information for each VLAN currently configured into the device by (local or network) management, or dynamically created as a result of GVRP requests received. | ||
| N.Topology.Snmp.Layer2 | vmMembershipSummaryTable | 1.3.6.1.4.1.9.9.68.1.2.1 |
| A summary of VLAN membership of non-trunk bridge ports. This is a convenience table for retrieving VLAN membership information. A row is created for a VLAN if:
| N.Topology.Snmp.Layer3 | ipNetToMediaTable | 1.3.6.1.2.1.4.22 |
| The IPv4 Address Translation table used for mapping from IPv4 addresses to physical addresses. This table has been deprecated, as a new IP version-neutral table has been added. It is loosely replaced by the ipNetToPhysicalTable. | ||
| N.Topology_CDP.SNMP.cdpCacheTable | cdpCacheAddressType cdpCacheAddress cdpCacheDeviceId cdpCacheDevicePort | 1.3.6.1.4.1.9.9.23.1.2.1.1.3 1.3.6.1.4.1.9.9.23.1.2.1.1.4 1.3.6.1.4.1.9.9.23.1.2.1.1.6 1.3.6.1.4.1.9.9.23.1.2.1.1.7 |
| L2 entries gathering for CISCO-CDP-MIB | ||
| N.Topology_Layer2.SNMP.Dot1dTpFdb | dot1dTpFdbPort dot1dTpFdbAddress dot1dTpFdbStatus | 1.3.6.1.2.1.17.4.3.1.2 1.3.6.1.2.1.17.4.3.1.1 1.3.6.1.2.1.17.4.3.1.3 |
| L2 entries gathering for BRIDGE-MIB (community string indexing) | ||
| N.Topology_Layer2.SNMP.Dot1dTpFdbNoVLANs | dot1dTpFdbPort dot1dTpFdbAddress dot1dTpFdbStatus | 1.3.6.1.2.1.17.4.3.1.2 1.3.6.1.2.1.17.4.3.1.1 1.3.6.1.2.1.17.4.3.1.3 |
| L2 entries gathering for BRIDGE-MIB | ||
| N.Topology_Layer2.SNMP.Dot1qTpFdb | dot1qTpFdbPort dot1qTpFdbAddress dot1qTpFdbStatus | 1.3.6.1.2.1.17.7.1.2.2.1.2 1.3.6.1.2.1.17.7.1.2.2.1.1 1.3.6.1.2.1.17.7.1.2.2.1.3 |
| L2 entries gathering for Q-BRIDGE-MIB (community string indexing) | ||
| N.Topology_Layer2.SNMP.Dot1qTpFdbNoVLANs | dot1qTpFdbPort dot1qTpFdbAddress dot1qTpFdbStatus | 1.3.6.1.2.1.17.7.1.2.2.1.2 1.3.6.1.2.1.17.7.1.2.2.1.1 1.3.6.1.2.1.17.7.1.2.2.1.3 |
| L2 entries gathering for Q-BRIDGE-MIB | ||
| N.Topology_Layer3.SNMP.ipNetToMedia | ipNetToMediaIfIndex ipNetToMediaPhysAddress ipNetToMediaType | 1.3.6.1.2.1.4.22.1.1 1.3.6.1.2.1.4.22.1.3 1.3.6.1.2.1.4.22.1.4 |
| Layer3 poller for devices which supports IP-MIB | ||
| N.Topology_LLDP.SNMP.lldpRemoteSystemsData | lldpRemManAddrIfSubtype lldpRemManAddrIfId lldpRemPortId lldpRemPortDesc lldpRemSysName lldpRemChassisId | 1.0.8802.1.1.2.1.4.2.1.3 1.0.8802.1.1.2.1.4.2.1.4 1.0.8802.1.1.2.1.4.1.1.7 1.0.8802.1.1.2.1.4.1.1.8 1.0.8802.1.1.2.1.4.1.1.9 1.0.8802.1.1.2.1.4.1.1.5 |
| Topology poller for L2 entries gathering for devices which support LLDP-MIB | ||
| N.Topology_PortsMap.SNMP.Dot1dBase | dot1dBasePort dot1dBasePortIfIndex | 1.3.6.1.2.1.17.1.4.1.1 1.3.6.1.2.1.17.1.4.1.2 |
| BRIDGE-MIB with community string indexing | ||
| N.Topology_PortsMap.SNMP.Dot1dBaseNoVLANs | dot1dBasePort dot1dBasePortIfIndex | 1.3.6.1.2.1.17.1.4.1.1 1.3.6.1.2.1.17.1.4.1.2 |
| PortID to IfIndex map gathering for BRIDGE-MIB | ||
| N.Topology_Vlans.SNMP.Dot1q |
dot1qVlanIndex
| 1.3.6.1.2.1.17.7.1.4.2.1.2 |
| Q-BRIDGE-MIB | ||
| N.Topology_Vlans.SNMP.VmMembershipSummary | vmMembershipSummaryTable | 1.3.6.1.4.1.9.9.68.1.2.1 |
| CISCO-VLAN-MEMBERSHIP-MIB | ||
| N.Topology_Vlans.SNMP.VtpVlan | vtpVlanTable | 1.3.6.1.4.1.9.9.46.1.3.1 |
| CISCO-VTP-MIB | ||
| N.IPAddress.ICMP.Generic Node.IPAddresses.ICMPIPAddressesPoller | N/A | N/A |
| Performs reverse/forward DNS lookup to gather IP addresses for ICMP nodes | ||
| N.IPAddress.SNMP.Generic Node.IPAddresses.SNMPIPAddressesPoller | ipAdEntAddr | 1.3.6.1.2.1.4.20.1.1 |
| The IPv4 address to which this entry's addressing information pertains. Performs reverse/forward DNS lookup to gather IP addresses | ||
| N.IPAddress.SNMP.Generic Node.IPAddresses.SNMPIPAddressesPoller | ipv6AddrAddress | 1.3.6.1.2.1.55.1.8.1.1 |
| Performs reverse/forward DNS lookup to gather IPv6 addresses | ||
| N.IPAddress.WMI.Generic Node.IPAddresses.WmiIPAddressesPoller | N/A | N/A |
IP addresses poller for WMI devices Generic poller for Windows 2000 or newer. Performs reverse/forward DNS lookup to gather IP addresses. The following WMI query is used: | ||
| N.Details.SNMP.Generic Node.SNMP.NodeDetailsPoller | multiple | multiple |
Node details poller for devices which support RFC1213-MIB and IF-MIB utilized in node rediscovery Poller utilizes GET-REQUEST to gather basic details about node using OIDs:
| N.Topology_STP.SNMP.Dot1dStp | dot1dBaseBridgeAddress Dot1DStpPriority Dot1DStpPort Dot1DStpPortState Dot1DStpPortEnable Dot1DStpPortDesignedRoot Dot1DStpPortDesignedBridge Dot1DStpPortDesignedPort | 1.3.6.1.2.1.17.1.1 1.3.6.1.2.1.17.2.2 1.3.6.1.2.1.17.2.15.1.1 1.3.6.1.2.1.17.2.15.1.3 1.3.6.1.2.1.17.2.15.1.4 1.3.6.1.2.1.17.2.15.1.6 1.3.6.1.2.1.17.2.15.1.8 1.3.6.1.2.1.17.2.15.1.9 |
| Poller for STP (Spanning Tree Protocol) entries. Poller utilizes GetTable request to gather Bridge Id, Port Number, Port State, enabled/disabled status of the port, port's designated root, bridge, and port using OIDs. | ||
| N.Topology_Layer3_IpRouting.SNMP.ipCidrRouter | ipCidrRouteDest ipCidrRouteIfIndex ipCidrRouteNextHop ipCidrRouteType ipCidrRouteMask | 1.3.6.1.2.1.4.24.4.1.1 1.3.6.1.2.1.4.24.4.1.5 1.3.6.1.2.1.4.24.4.1.4 1.3.6.1.2.1.4.24.4.1.6 1.3.6.1.2.1.4.24.4.1.2 |
| Poller utilizes GetTable request to gather ipCidrRouteDest, ipCidrRouteIfIndex, ipCidrRouteNextHop, ipCidrRouteType and ipCidrRouteMask using OID | ||
| N.Topology_Layer3_IpRouting.SNMP.ipForwardRouter | IpForwardDest IpForwardIfIndex IpForwardNextHop IpForwardType IpForwardMask | 1.3.6.1.2.1.4.24.2.1.1 1.3.6.1.2.1.4.24.2.1.5 1.3.6.1.2.1.4.24.2.1.4 1.3.6.1.2.1.4.24.2.1.6 1.3.6.1.2.1.4.24.2.1.2 |
| Poller for L3 IPForward entries. Poller utilizes GetTable request to gather IpForwardDest, IpForwardIfIndex, IpForwardNextHop, IpForwardType and IpForwardMask using OIDs. | ||
