OIDs polled for EIGRP
Data polled from EIGRP enabled devices with the corresponding OIDs
EIGRP was originally a proprietary Cisco routing protocol, only available on Cisco routers. Although it became an open protocol in 2013, our EIGRP support is focusing on Cisco devices and only uses Cisco EIGRP MIBs.
If the device responds to 1.3.6.1.4.1.9.9.449.1.4, this poller is supported. The peer protocol status is always "Established" because cEigrpPeer table only stores established peers.
NPM polls the following OIDs:
| OID | Name | TableColumn |
| 1.3.6.1.4.1.9.9.449.1.4.1.1.3 | cEigrpPeerAddr | NeighborIdentifier |
| 1.3.6.1.4.1.9.9.449.1.4.1.1.2 | cEigrpPeerAddrType | IP_address_Type, IP_version |
| 1.3.6.1.4.1.9.9.449.1.4.1.1.3 | cEigrpPeerAddr | NeighborIP, NeighborIPGUID |
| 1.3.6.1.4.1.9.9.449.1.4.1.1.4 | cEigrpPeerIfIndex | LocalProtocolInterfaceIndex |
