Nutanix Clusters are not showing after successfully adding it via 'Multiple Nutanix Cluster' option
This article provides information about the issue when after successfully adding Nutanix Clusters, it's missing and not showing on the Nutanix Summary page
4/12/2022 3:42 AM
4/8/2025 11:14 PM
After successfully adding Nutanix Clusters, it's missing and not showing on the Nutanix Summary page
The Network Discovery shows were successfully added but it's not showing on the Virtualization page
Network Performance Monitor
Nutanix Discovery timeout expires due to huge Prism Central Nutanix Cluster environment
Increase Discovery timeout for Nutanix
  1. Go to the Advance Configuration page to http://YourMachineIP/Orion/Admin/AdvancedConfiguration/Global.aspx
  2. Log in as an Admin
  3. Navigate to SolarWinds.Orion.Nutanix.DiscoveryPlugin.NutanixDiscoveryPluginSettings
  4. Increase ProbeTimeout (default value is 10 seconds)
  5. Click on the Save button
  6. Testing adding the Nutanix Cluster again.
