Tools
Not able to see UAC prompt when on a remote DRE session
This article shows how to resolve and remove the black screen that appears when the UAC prompts during a remote DRE session
By design, DRE agent service does not have the ability to elevate any domain user privileges and would depend deeply on the DRE technician's access level within the domain and remote host as a domain resource.
When performing a task that requires an admin permission during the DRE session, the selected value for "User Account Control: Switch to the secure desktop when prompting for elevation" determines where the prompt would appear:
- Enabled: (Default) All elevation requests go to the secure desktop regardless of prompt behavior policy settings for administrators and standard users
- Disabled, All elevation requests go to the interactive user's desktop. Prompt behavior policy settings for administrators and standard users are used.
Also, the UAC prompt will not appear on the secure desktop if the UAC switch registry is missing or corrupted.
2. On the Registry Editor:
Locate and right-click HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\Policies\System\ConsentPromptBehaviorAdmin, and then click Delete.
Right-click HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\Policies\System, point to New, and then click DWORD Value.
Type ConsentPromptBehaviorAdmin, and then press ENTER.
Right-click ConsentPromptBehaviorAdmin, and then click Modify.
In the Value data box, type 5, and then click OK.
Locate and right-click HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\Policies\System\PromptOnSecureDesktop, and then click Delete.
Type PromptOnSecureDesktop, and then press ENTER.
Right-click PromptOnSecureDesktop, and then click Modify.
In the Value data box, type 1, and then click OK
For additional information regarding UAC not showing on secure remote desktop, see https://docs.microsoft.com/en-us/previous-versions/windows/it-pro/windows-server-2008-R2-and-2008/ee844168(v%3dws.10 © Microsoft 2020 available at https://docs.microsoft.com/
obtained on March 27, 2020)
Disclaimer: Please note, any content posted herein is provided as a suggestion or recommendation to you for your internal use. This is not part of the SolarWinds software or documentation that you purchased from SolarWinds, and the information set forth herein may come from third parties. Your organization should internally review and assess to what extent, if any, such custom scripts or recommendations will be incorporated into your environment. You elect to use third party content at your own risk, and you will be solely responsible for the incorporation of the same, if any.
