Tools
Getting attended and unattended session errors when establishing remote connection in Dameware Mini Remote Control (MRC)
This article explains why MRC users get error messages such as "Following Internet Session link is not valid or expired" or "Remote host in unreachable" when attempting to establish a session using Dameware Internet Proxy.
Note: You must use only one of the settings--either the server (internet proxy) or the client (remote host with MRC agent) setting, not both. SolarWinds recommends using the server-side setting because it ensures that the issue is solved for all client computers.
- HTTP/2 is enabled on either the internet proxy or the remote host side.
- MRC does not support HTTP/2 protocol for attended or unattended sessions.
Perform the following procedure to add a new registry key on the internet proxy server.
Warning: SolarWinds strongly recommends that you back up your registry before editing it. Only edit the registry if you are experienced and confident in doing so. Using a registry editor incorrectly can cause serious issues with your operating system, which could require you to reinstall your OS to correct them. SolarWinds cannot guarantee resolutions to any damage resulting from making registry edits.
- Log in to the system hosting the internet proxy, and open Registry Editor.
- Navigate to the following registry key: HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\HTTP\Parameters
- Create or update a DWORD value with the following name: EnableHttp2Tls
- Set the DWORD value to 0.
- Close Registry Editor, and restart the machine.
Alternatively, the following procedure can be performed on the remote host if the internet proxy is inaccessible:
- Log in to the remote host, and open Registry Editor.
- Navigate to the following registry key: HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Internet Settings\WinHttp
- Create or update a DWORD value with the following name: EnableDefaultHttp2
- Close Registry Editor, and restart the MRC agent service (or the entire machine).
