Tools
Non-Admin Access to Remote Connection Using DMRC is not working even after Enabling Non-Admin Access to the DMRC Agent
This article provides information on issues when doing a remote connection using a non-admin account even after they have already enabled a remote connection for a non-admin account.
For Target Remote machines that already have an installed Dameware Mini Remote Control Service, you can choose to allow non-admin access for the remote connection by referring to this documentation article:
Modify Dameware client agent permissions to enable or prevent non-administrator access
If after configuring the agent in this manner you're still experiencing issues, there may be a possibility that there is a missing configuration in the GPO of the environment.
- Environmental Issue
- Make Sure that the "Allowed Non-Admin settings" has been configured in all of your Dameware Mini Remote Control Agent
- Enable the "Access this computer from the network” from the GPO.
- Reference: Access this computer from the network - security policy setting
- Disclaimer: Please note, any content posted herein is provided as a suggestion or recommendation to you for your internal use. This is not part of the SolarWinds software or documentation that you purchased from SolarWinds, and the information set forth herein may come from third parties. Your organization should internally review and assess to what extent, if any, such custom scripts or recommendations will be incorporated into your environment. You elect to use third party content at your own risk, and you will be solely responsible for the incorporation of the same, if any.
