Nodes polled using Node Details device pollers are not rediscovered
When you create a Node Detail device poller with the Automatically poll nodes during network discovery... option enabled, the details pollers are disabled after discovery results are reimported.
In the Device Studio "Node Detail" poller, ensure that Automatically poll nodes during network discovery... is not selected.
Recreate all Discovery Profiles and use only the new profiles to import Discovery results.
From the Manage Pollers page, verify that the Device Studio "Node Detail" poller is assigned and Enabled on your nodes.
If you are not willing to recreate all Discovery Profiles, you can remove discovered "Node Detail" Device Studio pollers.
