"Allow Node Management Rights" with disabled "Allow Administrator Rights", missing Manage Nodes drop down in Orion Platform
A user has "Allow Administrator Rights" disabled, and is required to manage Nodes. "Allow Node Management Rights" is enabled, but the drop-down for "Manage Nodes" is not available.
2. If the "Allow Administrator Rights" is disabled from the user, the drop-down will only show "Manage Dashboards".
3. This is by design.
4. To manage Nodes when "Allow Node Management Rights" is enabled, with the drop-down to Manage Nodes not available, you will need to use the "All Nodes" widget.
Workaround 1
Use the "Manage Nodes" option of the "All Nodes" resource which may be found on the Summary Page of My Dashboards >> Home, Network, or Network Configuration:Workaround 2
Create and add "Manage Nodes" to the menubar:- Navigate to Settings > All Settings > Manage Accounts and edit the account in question.
- Scroll down to the Default Menu Bar and Views section and confirm the setting for the HomeTab Menu Bar:
- Using an Orion Admin account, Click My Dashboards > Configure or Settings > All Settings > Customize Menu Bars
- Edit the Menu Bar and select Manage Nodes from Available Items (Left) and drag it to the Selected Items (Right)
- Submit the change and test with the user account - the assigned User will see it in their respective Menu bar:
