Security Compliance
No connection could be made in Patch Manager because the target machine actively refused it
This article addresses an issue that prevents Patch Manager from communicating with the WSUS server.
11/29/2018 10:35 PM
11/29/2018 10:35 PM
When you add a WSUS server to Patch Manager, the following error displays:
Could not connect to server:
Exception occurred at
No connection could be made because the target machine actively refused it
Patch Manager
The WSUS server is not responding on the appropriate port. As a result, Patch Manager cannot connect to the WSUS server.
Verify that:
  1. The WSUS server is installed and configured properly.
  2. The WSUS listening port  is correct.
  3. Patch Manager is able to resolve the WSUS server and the port included in the Connection Wizard is correct.
  4. The WSUS server has no errors in the Windows Event and Application logs and is functioning correctly.
