Applications Systems
No VMs and Datastore data on Orion Virtualization Summary
This article will provide a possible solution for the issue where VMAN is unable to send data to the Orion server. Orion Virtualization summary is not showing any VM's or Datastore data.
However, upon further checking. It was found that the Orion server has two NICs and VMAN is suppose to send the data on NIC 1 (with the correct IP address) instead on NIC 2 (with the incorrect IP address). So the issue is with the incorrect IP address that is assigned to the Orion primary module engine. Running the Configuration Wizard does not correct the issue and it was found that NIC 1 is the primary NIC.
Workaround:
Disable NIC 2 then run Configuration Wizard. This will force Configuration Wizard to use the NIC 1 IP address.
Reintegrate VMAN to the Orion server and run VMAN Synchronization Wizard.
