Tools
Network map drive is not accessible even Serv-U is running as an application
This article details why the network map drive is not showing or accessible in Serv-U, even running as an application.
1. Open Windows registry by running "Regedit."
2. Locate and then right-click the following registry subkey:
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Policies\System
3. Point to New, and then click DWORD Value.
4. Type EnableLinkedConnections, and then press ENTER.
5. Right-click EnableLinkedConnections, and then click Modify.
6. In the Value data box, type 1, and then click OK.
7. Exit Registry Editor, and then restart the computer.
