Network Discovery fails for multiple devices using SNMPv3
How to resolve an issue where Network Discovery fails for multiple devices using SNMPv3.
This is a known issue that is tracked by Cisco as CSCub61401. In short, a defect in certain Cisco devices forces the occupation of all available SNMP threads. In this case, the defective device is not detected as SNMP-enabled, and ICMP is used for discovery and monitoring. Until the issue is fixed by Cisco, devices may be added individually, as necessary.
This article applies to SolarWinds products using Orion Core Platform 2012.2 and higher
Disclaimer: Please note, any content posted herein is provided as a suggestion or recommendation to you for your internal use. This is not part of the SolarWinds software or documentation that you purchased from SolarWinds, and the information set forth herein may come from third parties. Your organization should internally review and assess to what extent, if any, such custom scripts or recommendations will be incorporated into your environment. You elect to use third party content at your own risk, and you will be solely responsible for the incorporation of the same, if any.
