Network Atlas not showing L2 connections
How to resolve an issue where Network Atlas is not showing L2 connections with Connect now
- Open the file calculation.cfg. This can be found in either: c:\programfiles(x86)\solarwinds\orion or: c:\programfiles(x86)\solarwinds\orion\topology
- Find the line: <string>RemoveLinksToBridge</string> and delete it.
- Run SolarWinds.Orion.Topology.Calculator.exe (also present in the same directory).
Verify results in the Network Atlas after re-opening the map and using the Connect Now function..
