Netpath probe is stuck on 'First poll not yet complete' message in SolarWinds Platform
There is no data being collected on the Netpath probes.
Once adding a new Netpath probe, it shows a "First poll not yet complete" message.
In the Netpath log (C:\ProgramData\SolarWinds\Logs\NetPath), it shows the following error:
ERROR SolarWinds.NetPath.Pollers.CommonPollerBase`2 - (null) Exception in processing job.SolarWinds.NetPath.Shared.ErrorCodes.NetPathException: Exception of type 'SolarWinds.NetPath.Shared.ErrorCodes.NetPathException' was thrown. ---> System.NullReferenceException: Object reference not set to an instance of an object. at SolarWinds.NetPath.Probe.Contract.Models.Settings.Load(String path) at System.Lazy`1.CreateValue() at System.Lazy`1.LazyInitValue() at SolarWinds.NetPath.Pollers.Traceroute.TraceroutePoller.ExecuteInternal(TraceroutePollerResult result, TraceroutePollerSettings settings) at SolarWinds.NetPath.Pollers.CommonPollerBase`2.ExecuteAsync(IJobExecutionHost host, CancellationToken cancellationToken) --- End of inner exception stack trace ---
The NetPathAgent.cfg file stored in C:\ProgramData\SolarWinds\Orion\NetPath folder is corrupted or with 0 size.
Follow the steps to fix the corrupted NetPathAgent.cfg file:
- Check the
NetPathAgent.cfgfile fromC:\ProgramData\SolarWinds\Orion\NetPath\ - The size should be, by default, 2KB.
- If it is empty (0kb), delete the file.
- Restart the SolarWinds Services.
- The file will be recreated with a 2KB size.
- NetPath Probes will start to display data after successfully polling.
