Netflow data is unavailable on Cisco Nexus devices in NTA
Netflow data is unavailable on some Cisco Nexus devices configured to use Netflow v5. This devices can still be configured but Flexibe Netflow is still recommended for use. Data will not be processed if the values do not match the information in flow data when the device is discovered.
Flow data contains interface index value fields InputInt and OutputInt. These fields in Netflow v5 are 2 bytes and can only hold a maximum value of 65535. Netflow v9 on the other hand, uses 4 bytes and can hold a maximum value of 4294967295. Since v5 cannot hold the entire value, the InputInt and OutputInt fields are changed and do not match the interface index values in the database. The packets are then dropped since the values exported using v5 are changed and does not represent the matching SNMP interface index values.
This can be verified using a Wireshark capture and an SNMP walk to compare the interface index values.
Wireshark
InputIfIndex |
OutputIfIndex |
3096 |
200 |
3096 |
253 |
3096 |
253 |
3096 |
253 |
3096 |
151 |
3096 |
151 |
SNMP values when discovered
InterfaceIndex |
151060481 |
151060499 |
151060628 |
151060631 |
151060640 |
151060641 |
151060667 |
151060680 |
