NetObjectId is Null for UNDPN events
By design, the NetObjectId is Null for UNDPN events in the Events table.
12/2/2025 12:36 PM
12/2/2025 4:47 PM
By design, the NetObjectId is Null for UNDN events in the Events table.
In the Events table, the issue happens with only one event for NetObjectType=UNDPN:
EventID
EventTime
NetworkNode
NetObjectID
NetObjectID2
EventType
Message
Acknowledged
EngineID
NetObjectType
TimeStamp
NetObjectValue
158695701
2025-11-26T14:04:34.2000000
3825
NULL
NULL
5000
[PagerDuty] Node EMEA1PUPS01 is Running On Battery. Severity: Critical
FALSE
4
UNDPN
System.Byte[8]
3bf33b49-3f50-420b-a13d-f937a94f7147
This does not affect SolarWinds Platform, but affects the ServiceNow integration called: SolarWinds for ITOM Health: SolarWinds Events and ServiceNow Event Management module
As the NetObjectID is NULL for NetObjectType=UNDPN, the ServiceNow integration "SolarWinds for ITOM Health: SolarWinds Events and ServiceNow Event Management module" does not bring in the data event, as their query relies on the NetObjectID column.
This happens because the integration uses the following query to fetch the data:
SELECT TOP [MAX_EVENTS_TO_FETCH] EventID, EventTime, NetworkNode, NetObjectID, EventType, Message, Acknowledged, NetObjectType, Timestamp FROM Orion.Events WHERE NetworkNode >= 0 AND NetObjectID > 0
Network Performance Monitor
-- out of the use of or inability to use the scripts or documentation
The "SolarWinds for ITOM Health: SolarWinds Events and ServiceNow Event Management module" SeviceNow integration was developed and is maintained by ServiceNow. See more details here: ServiceNow and SolarWinds Platform integrations
As a workaround, you can modify the query to something as shown below or directly consult the ServiceNow Technical Support team:
SELECT TOP [MAX_EVENTS_TO_FETCH] EventID, EventTime, NetworkNode, NetObjectID, EventType, Message, Acknowledged, NetObjectType, Timestamp FROM Orion.Events WHERE NetworkNode >= 0 AND (NetObjectID > 0 OR NetObjectType = ‘UNDPN’)
