NetFlow Configuration Example - Cisco ASA
In order to see flow data from your Cisco ASA in SolarWinds NTA, you must configure the device to export flow data. This article includes an example config you can use to build your own config specific to your environment.
11/29/2018 10:47 PM
1/31/2026 12:06 AM
In order to see flow data from your Cisco ASA 55xx-x in SolarWinds NTA, you must configure the device to export flow data. This article includes an example configuration you can use to build your own configuration specific to your environment.
Netflow Traffic Analyzer
Configuration example:
flow-export destination inside 1.1.1.1 2055
flow-export template timeout-rate 1
flow-export delay flow-create 60
access-list netflow-export extended permit ip any any
class-map netflow-export-class
match access-list netflow-export
policy-map global_policy
class netflow-export-class
flow-export event-type all destination 1.1.1.1
service-policy global_policy global
You can only configure a device through the ASDM console per security reasons. Below is an article of an example configuration walk through:
https://supportforums.cisco.com/docu...tflow-asa-asdm  (© 2018 Cisco Systems Inc., available at https://community.cisco.com, obtained on January 20, 2019)
Helpful links
Link to Cisco ASA 9.1.(2) or higher software version Netflow configuration:
Updated Cisco ASA Netflow configuration when running software version 9.1.(2) or later
