NTA service not starting after installation of Hotfix or upgrade
NTA Serice is Stopping/Flapping after upgrade in Orion Services
- NTA Service is unable to start after an upgrade or installation of a Hotfix
- NTA Business layer Log Contains following ERROR;
** Assembly SolarWinds.Netflow.IoC, Version=4.7.0.8139, Culture=neutral, PublicKeyToken=null, .NET version v4.0.30319 ***
[9] ERROR SolarWinds.NetFlow.Service.Program - NetFlowService will be abnormally terminated - Unhandled exception.
System.Reflection.TargetInvocationException: Exception has been thrown by the target of an invocation. ---> System.IO.FileNotFoundException: Could not load file or assembly 'SolarWinds.Orion.Core.BusinessLayer, Version=2019.4.5200.8890, Culture=neutral, PublicKeyToken=null' or one of its dependencies. The system cannot find the file specified.
The Solarwinds Business layer DLL was Blocked preventing the NTA Service from starting.
Path to DLL "C:\Program Files (x86)\SolarWinds\Orion"
Full Filename 'SolarWinds.Orion.Core.BusinessLayer.dll
The Error message is referencing a DLL file "System.IO.FileNotFoundException: Could not load file or assembly 'SolarWinds.Orion.Core.BusinessLayer, Version=2019.4.5200.8890"
- From the Error message locate the File path of the DLL.
- Confirm that the Correct version Number of the DLL is present on the system
In this particular case, the DLL happened to be Blocked
To resolve
- Right Click on the dll File
- Select properties
- Unblock the dll File
If the dll file is missing, run a repair of the SolarWinds Platform via the Control Panel and complete the Configuration Wizard.
