NTA drops NetFlow v9/IPFIX flows with “Missing mandatory fields: Bytes (1) or OutBytes (23) or Bytes (85) or InitiatorOctets (231) or ResponderOctets (232)” in NTA Business Layer log
SolarWinds NTA can only store flows from NetFlow v9/IPFIX/NSEL templates that include all mandatory fields defined in the “Required fields in SolarWinds NTA” schema, including at least one Bytes-group counter. When an exporter sends templates that lack any Bytes-group field (Bytes 1/85, OutBytes 23, InitiatorOctets 231, ResponderOctets 232), NTA logs “Missing mandatory fields: Bytes (1) or OutBytes (23) or Bytes (85) or InitiatorOctets (231) or ResponderOctets (232)” and discards those flows by design. This is resolved only by adjusting the exporter’s template/record or device firmware, not by changing NTA. Common search phrases: “Missing mandatory fields Bytes (1) OutBytes (23) InitiatorOctets (231) ResponderOctets (232)” “NTA invalid V9Template” “NetFlow v9 no data from FTD / ASA / firewall in NTA” “Last received NetFlow never but pcap shows flows”
Problem / Symptoms
- NetFlow/NSEL/IPFIX data from one or more devices (often firewalls such as Cisco FTD/ASA, SD-WAN, or routers) is not visible in SolarWinds NTA:
- “Last Received NetFlow” shows Never or an old timestamp.
- NTA resources show no conversations, no top talkers, or incomplete traffic for specific devices, while other devices work.
- Packet captures on the SolarWinds collector show NetFlow v9/IPFIX/NSEL traffic arriving on the expected UDP port (for example, 2055), but no flows appear in the NTA web console.
- NTA is otherwise functioning; other exporters send flows that NTA displays correctly.
Exact error message in logs
In NTA.BusinessLayer.log you see entries similar to:
Template contains fields: …
(Template IDs and field lists vary by device, but the “Missing mandatory fields…” line is consistent.)
What this article explains
- What this log message means for NTA and why flows are not displayed.
- How to confirm the issue using NTA logs and packet captures (Wireshark).
- Why this cannot be fixed in NTA and must be addressed on the device/exporter side.
- What changes are required on the exporter (flow record/profile/template) and what options you have if the device cannot be changed.
SolarWinds NTA enforces a required-fields schema for NetFlow v9/IPFIX/NSEL templates (see “Required fields in SolarWinds NTA”). Each flow template must include:
- Protocol
- Source address (IPv4/IPv6)
- Destination address (IPv4/IPv6)
- At least one Interfaces group field:
InterfaceRx– Field Type 10 (SNMP ingress interface index), orInterfaceTx– Field Type 14 (SNMP egress interface index)
- At least one Bytes group field (this article’s focus):
Bytes– Field Type 1 (delta bytes), orBytes– Field Type 85 (total bytes), orOutBytes– Field Type 23, orInitiatorOctets– Field Type 231, orResponderOctets– Field Type 232
Root cause
- The affected device (exporter) is sending NetFlow v9/IPFIX/NSEL templates that do not include any Bytes-group field (none of IDs 1, 23, 85, 231, 232 are present in those templates).
- When NTA decodes such a template, it logs “Missing mandatory fields: Bytes (1) or OutBytes (23) or Bytes (85) or InitiatorOctets (231) or ResponderOctets (232)” and drops all flows that use that template.
- Other templates from the same exporter that do include a Bytes-group field (for example, those containing
initiatorOctets (231)andresponderOctets (232)) are accepted; the problem affects only the templates missing these fields.
This behavior is by design and consistent across NTA versions; it is not a regression caused by an upgrade, migration (including to Azure), or configuration change on the SolarWinds side.
Important: This issue cannot be fixed in NTA. There is no setting, hotfix, or unsupported configuration that safely bypasses the required-fields schema. The resolution is always on the exporter/device side.
Step 1 – Confirm the issue
Check NTA Business Layer log
- On the SolarWinds server, open
NTA.BusinessLayer.log(from Orion/Platform diagnostics). - Search for:
Missing mandatory fields: Bytes (1) or OutBytes (23) or Bytes (85) or InitiatorOctets (231) or ResponderOctets (232)text -
Note the exporter IP address and Template ID mentioned in nearby lines (
Template contains fields: …).
Validate template content in Wireshark (optional but recommended)
- Capture NetFlow v9/IPFIX/NSEL traffic on the SolarWinds collector (UDP port, e.g., 2055).
- Open the pcap in Wireshark and decode as
cflowif needed. - Filter for template packets:
cflow.template_idtext -
For a template from the affected exporter:
- Expand Cisco NetFlow/IPFIX → Template FlowSet (Id = 0) → Template (Id = X).
- Review the Field Type IDs.
- Confirm that none of the Bytes-group IDs (1, 23, 85, 231, 232) appear.
Step 2 – Change the exporter configuration (device/vendor side)
Work with the device vendor (for example, Cisco TAC for FTD/ASA, SD-WAN vendor, router vendor) to ensure:
- At least one template that NTA should consume includes all mandatory fields, including one of the Bytes-group fields listed above.
- This typically involves:
- Adjusting the NetFlow v9 / Flexible NetFlow / NSEL / IPFIX record or profile to collect a bytes/octets counter.
- Ensuring the active policy/class map for the traffic sent to SolarWinds uses that record/profile.
- In some platforms, upgrading to a firmware/software version that supports an appropriate record type.
Once the exporter sends a compliant template, NTA will stop logging “Missing mandatory fields…” for that Template ID and will store flows using that template.
Step 3 – If exporter cannot be changed
If the vendor confirms that the current device/platform/version:
- cannot add any of the Bytes-group fields (1, 23, 85, 231, 232) to its NetFlow v9/IPFIX/NSEL templates,
then:
- This is a device limitation, not a SolarWinds defect.
- NTA will continue to drop flows from those templates.
- Options:
- Use NTA for other exporters that meet the required-fields schema.
- Use SNMP, syslog, or security/event tools for visibility into that device’s traffic instead of flow data.
- Optionally, request an enhancement via their SolarWinds account team for NTA to evaluate support for those specific non-standard templates (no guarantees and long-term only).
