NTA Virtual Interface reporting traffic instead of desired interface
You may find a number of unmonitored interfaces reporting data as "NTA Virtual Interface ####" where the #### is a sequential number. This implies that the NTA Collector is receiving flows from a managed node but one that is not responding via SNMP, and thus unable to associate a known interface with the flow conversation data.
This article discusses the issue where a number of unmonitored interfaces are reported data as the following:
NTA Interface ####
*where #### is a sequential number
Devices configured to export NetFlow are sometimes able to export the NetFlow summarization packets to the NTA Collector with a source address that does not match an existing node. In addition, this can be caused by using the Null interface to export data.
