NTA Top Conversation Chart not showing accurate data for specific interface
The topic provides the cause and resolution for the issue when the NTA Top Conversation chart shows inaccurate information on an interface.
11/6/2018 12:09 PM
3/14/2022 6:12 AM
This article provides brief information and steps to resolve the issue when the NTA Top Conversation chart shows inaccurate information on an interface.
Netflow Traffic Analyzer
The issue is caused by the sample rate not automatically detected.
  1. In your Orion Web Console, go to Settings.
  2. Under Product Specific Settings, click NTA Settings.
  3. Under NetFlow Sources, click Manually manage NetFlow Sources and CBQoS Polling.
  4. In the Show drop-down, select ALL.
  5. Find the target Interface.
  6. If the NetFlow Sample rate is not set to Auto-Detect: no Sampling,  click Edit.
  7. Clear Override auto-detected sampling rate and click Save.
