NTA - How to configure Juniper SRX devices to export J-Flow
This article provides an example of configuring J-Flow on an SRX Series device. NOTE: SRX devices support J-Flow versions 5 and 8. SolarWinds Netflow only supports and will process J-Flow version 5.
Configuration Example
The following procedure provides an example of J-Flow configuration.
- Enable sampling on one or more interfaces, and specify the direction:
user@host# set interfaces ge-0/0/0 unit 0 family inet sampling input
user@host# set interfaces ge-0/0/0 unit 0 family inet sampling output
- Specify the sampling rate.
Caution: Activation of flow collection can have a significant impact on the performance of the SRX Series device. The smaller the sample rate, the bigger the impact. We recommend that you do not use a sampling input rate of 1.
user@host# set forwarding-options sampling input rate 100
- Specify the UDP port number of the host that is collecting cflowd packets.
user@host# set forwarding-options sampling family inet output flow-server 10.10.10.1 port 2055
- Specify the version format: 5.
- user@host# set forwarding-options sampling family inet output flow-server 10.10.10.1 version 5
