NPM Licensing
This article describes the different NPM license tiers.
10/24/2018 5:10 PM
4/22/2025 5:23 PM
This article provides information on the NPM License tiers and how they are applied.
Network Performance Monitor
Licensing Scheme
NPM is licensed by the largest number of the following element types:
  • Nodes: include entire devices (routers, switches, servers, APs)
  • Interfaces: include switch ports, physical/virtual interfaces, VLANs, port-channel interfaces. Interface count is usually the largest.
    • Note: unmanaged interfaces still consume a license. To prevent interfaces from consuming a license, remove them from monitoring via List Resources.
  • Volumes: are equal to the logical disks you monitor
Example:
An Orion NPM SL2000 can monitor up to:
  • 2000 interfaces + up to 2000 nodes + up to 2000 volumes.
    • NPM Upgrades must ensure matching NTA upgrade licenses are included as well.
Licensing Tiers
LICENSE TIER
NODE LIMIT
VOLUME LIMIT
INTERFACE LIMIT
SL100
100
100
100
SL 250
250
250
250
SL 500
500
500
500
SL 2000
2000
2000
2000
SLX
Unlimited*
Unlimited*
Unlimited*
*With the default polling interval, one polling engine can monitor a maximum of 12,000 elements. To monitor over 12,000 elements, use additional polling engines (APEs) . Each APE requires a license.
