NPM checking the total number of elements with Orion diagnostics
2/15/2019 2:39 AM
11/29/2022 12:51 AM
In this article you will learn how to check the total number of elements you are monitoring using the  with Orion diagnostics
Orion Platform
Collect system diagnostics
1. RDP to the Main Poller
2. Go to Start > SolarWinds Orion > Orion Diagnostics
3. Click Start. A ZIP file is generated.
4. Right-click the file and select Extract Here.
Check the total number of elements (nodes, interfaces, volumes)  polled per server
1. Go to the DB folder.
2. Open the AllEngines.csv file.
Check the number of elements that you are polling per server.
Example below
EngineID
Elements
Nodes
Interfaces
Volumes
1
15828
934
6823
1071
2
16084
202
1305
77
With the SolarWinds SLX license, you can monitor up to 12,000 elements. Beyond this, additional polling engines on separate servers are recommended to help distribute the work load. For more details, see the Server Sizing recommendations.
For questions on polling beyond 12000 elements with a single SLX server, see Boost your server polling capacity with Stackable Poller license
